Single phase to three phase transformer
Discussion in 'General Electronics Chat' started by eegriega, Feb 10, 2016.
  1. eegriega
    Feb 10, 2016
    hello
    I have a hydraulic clicker press that runs on three phase. The workshop i have has single phase. What kind of transformer do i need to use for this piece of machinery? The motor is 1.5 horsepower and runs at 1430 rpm.
    I'm trying to find the cheapest way of doing this!
    cheers
  2. MaxHeadRoom
    Jul 18, 2013
    10,838
    2,512
    A VFD for the 3ph motor, Huanyang are the cheapest but not the ideal quality, Hitachi are a reliable second for a little more cost.
    Max.
  3. DNA Robotics
    Member
    Jun 13, 2014
    132
    33
    I have been using these for 30 years on motors from .5 to 10 HP.
  4. MaxHeadRoom
    Jul 18, 2013
    10,838
    2,512
    The only thing with these RPC methods is the maximum HP is not usually achieved due to current drop in L3.
    Max.
  5. Sonoran Desert Tortoise
    Member
    Oct 30, 2014
    53
    34
  6. eegriega
    Feb 10, 2016
  7. cmartinez
    Jan 17, 2007
    3,698
    2,779
  8. MaxHeadRoom
    Jul 18, 2013
    10,838
    2,512
    Yes, that the Huanyang unit, the manual is a little cryptic and virtually no support, but CHEAP!
    Max.
    cmartinez likes this.
  9. cmartinez
    Jan 17, 2007
    3,698
    2,779
    Affordable.... or inexpensive... but as for cheap, guess there's only one way to find out! ;)
  10. eegriega
    Feb 10, 2016
    thanks a lot for the replies :)
  11. tcmtech
    Nov 4, 2013
    2,111
    1,751
    The best down and dirty design I know of that also lets you have full rated power of your three phase motor while on single phase is this. It's been close to 20 years now since I designed and refined it and I have built too many to count now. Most still running on original parts too! :cool:
    http://www.electro-tech-online.com/threads/3-phase-converter-schematic-miller-system.100563/
    For a 1.5 HP hydraulic pump motor you would only need two ~15 uF run capacitors, a 100 - 150 uf start capacitor and a voltage sensing relay. All common items you can get at most any HVAC shop or online.
  12. MaxHeadRoom
    Jul 18, 2013
    10,838
    2,512
    I spent way more time than I should trying to decipher their twisted version of Modbus control that it also has.
    Max.
  13. cmartinez
    Jan 17, 2007
    3,698
    2,779
    I've been intending to learn (or use) modbus for a long time. But the truth is I see no reason to discard a standard uart network (be it rs232/485/422) if it is installed correctly and its protocol well and robustly programmed between devices.
  14. MaxHeadRoom
    Jul 18, 2013
    10,838
    2,512
    It was not the transmission medium but the S/W coding protocol, a form of Modbus.
    The system can be set for RTU (2x4bit hex) or ASCII.
    Actually I used RS232 from a PIC with a $3 convertor to RS485 to communicate with the VFD, you can use whatever you want for Modbus.
    Max.
