Can anyone help me please?
I have a GE 4Kw 5 Hp induction motor. It has been wired to run of three phase but I would like to run it on single phase. I have carried out research on the Internet but I am not confident with the information I have found.
I understand how to reconfigure the wiring of the three windings and I understand how start and run capacitors work. But other than using trial and error any information I have found has indicated that the start capacitor value should be anything from 120uf to 550uf and the run capacitor value should be between 10uf and 80uf. I would like to at least fairly accurate with values before trying out capacitors.
Has anyone got experience with a similar project or can point me in the right direction to working out the values of the capacitors.
I want to use this motor on a compressor and am confident that I can design the rest of the circuit to switch out the start capacitor and integrate the pressure sensing switch from the reserve tank but I would really appreciate any help you can give me with this.
Regards
Jim
Regards
Jim
