Hi
Got a single phase 370W induction motor that is coupled to a pump, I am planing to control the pressure directly trough the motor (not the valve method), so i looked around for a single phase VFD which is hard to get because not many manufacturers makes them with single phase output and they are a bit to expensive, so now i am thinking of using PWM to do the job, i got a few of these that can handle 10-15 Amps, what i have heard is that its a bad idea to control an induction motor using PWM, to my experience the PWM does not reduce the motor speed instead it reduce the Torque which under load will cause the motor to run slower (Correct me if i am wrong), What is the side effect of using the PWM method ? any better ideas beside the VFD method ?
Thanks in advance guys
