Vgs of the high side switch is in general the same as Vgs of the low side switch.Hi,
For a single phase inverter circuit,is it true that the Vgs of High side is always greater than the low side Vgs? is yes then why!!
Thank You
I think he is talking about a MOSFET with common drain..For a single phase inverter circuit,is it true that the Vgs of High side is always greater than the low side Vgs? is yes then why!!
I mean to ask Vgs applied to g1 should be higher than Vgs applied to g4? because for g4 mosfet, source is connected to ground, but for g1 mosfet, source is floating.Please post a diagram or the source of information you are referring to.
"Vgs" means the voltage from the gate to the source of the SAME MOSFET.I mean to ask Vgs applied to g1 should be higher than Vgs applied to g4? because for g4 mosfet, source is connected to ground, but for g1 mosfet, source is floating.
am i wrong?
by Aaron Carman
by Aaron Carman
by Jake Hertz
by Jake Hertz
