I have a Honda E900 generator that uses a CT(Current Transformer) to vary the DC voltage to the Field Rotor. It also uses an Inductor to supply voltage when there is no 120v load on the stator. The Inductor is under the Flywheel of the Motor so there is always some voltage on the rotor when there is no load on the stator. Problem is the motor is shot and I would like to use the generator portion with out the CT. I need a circuit designed to regulate the voltage to the field to maintain 120v ac on the stator under varying loads. I have determined that I need about 21 VDC .41A at no load and 60 VDC 1.12A at full load. I would like to add a transformer to the 120v supply to run the circuit and to get things started use a 12 or 24 v battery. I also need a circuit to charge the battery. I have some electronics experience but never designed circuits. Any help would be appreciated.
