There are two wires in there even if one of them is hiding.I stripped the wires and there is only a single wire.
It is a straight pug with a single output, like you would plug into a laptop. I stripped the wires and there is only a single wire.hi g,
What type of connector is at the end of the AC/DC adaptor, the 12Vdc end.?
E
It sys on the product details for the adapter that it is a single outputThere are two wires in there even if one of them is hiding.
There is one wire in the center of the cable, the other conductor is the braided/twisted shield around the the center wire.It sys on the product details for the adapter that it is a single output
Single output doesn't mean only one wire, it absolutely implies (at least) two wires - one being the positive and the other the negative.It sys on the product details for the adapter that it is a single output
by Jake Hertz
by Duane Benson
by Aaron Carman
by Aaron Carman
