single or 3 phase in my home?
Discussion in 'General Electronics Chat' started by CaliusOptimus, Apr 1, 2007.
Thread Status:
Not open for further replies.
  1. CaliusOptimus
    Aug 14, 2005
    59
    a few weekends ago i had to rewire a 220v welder from a 3 prong dryer plug, to a 4 prong. at lowe's i kept asking if the 4 prong plug is 3 phase wiring, the answer every time was 'whats 3 phase wiring?". i found a diagram for rewiring a dryer for a 4 prong and it worked fine for the welder, so i didnt worry about it. but now im curious to know if the 4 prong plug was connected to 3 phase wiring. is 3 phase a common thing in residential areas? if not, i dont see the purpose for an extra contact in the plug.
    (p.s. anyone have an oscilloscope they dont need? ill pay shipping!!) haha!
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    No, residential wiring is never three phase. You should have had four wire colors - black & red, the hot wires - while for the neutral, and green or bare for ground.
    Ain't no such thing as an unneeded o'scope.
  3. Sparkyfrm
    Apr 1, 2007
    You are correct, but in some location you will find Black, Blue for the Hot conductors instead of Black and red.
  4. CaliusOptimus
    Aug 14, 2005
    59
    so im assuming the black and red wires are basically the same wire.... ie same phase, voltage etc?
  5. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    No, they are 180 out of phase. The alternator that makes the AC has two coils, joined at one point to make the common line. The voltage out of either coil is 120 VAC individually, but 240 VAC across both.
  6. CaliusOptimus
    Aug 14, 2005
    59
    ahhh. ic, thank you!
  7. recca02
    Apr 2, 2007
    1,211
    well generally residential supplies are single phase with few homes as exception
    at least in my country , the three pins are for earthing 9the larger and bit longer one, one for a neutral and other for live wire.
    for a better answer try reading star and delta connections in transmission
    as far as i know we get power supply from star connection in our house
    which has one neutral and three diff phases 120 degrees out of phase.
    out of which one phase reaches ur house with a neutral. this system has its own advantages. i am not sure of the colour coding right now , what if someone has colour blindness???.:p
    i will send u a useless osc if u send me a useful one;)
  8. thingmaker3
    Retired Moderator
    May 16, 2005
    5,072
    6
Thread Status:
