Single FET AC Relay - Possible
Discussion in 'General Electronics Chat' started by Management, May 6, 2009.
  1. Management
    Thread Starter Active Member
    Sep 18, 2007
    306
    I know there are Solid State Relays to pass AC but is there way to wire up a single FET to block AC current when the FET is off?
    I know I can use a single one to pass that AC current but that inherent diode in the FET won't completely block AC current in both directions.
    Any way around that with one FET? Been trying to figure out a few tricks but can't.
    And no I don't want to use anything else. Just want to see if this is possible.
    Thanks.
  2. nanovate
    Distinguished Member
    May 7, 2007
    665
    Does it need to pass AC when it is on?
  3. Management
    Sep 18, 2007
    306
    Yes.
    I can make one FET pass AC when it is on but the issue is only when it is off does it not complete block AC. Is there anything I can do to get around that while using only one FET?
    Thank you.
  4. nanovate
    May 7, 2007
    665
    Nope the body diode will always conduct
