Single Ended Amplifier Question
Discussion in 'Homework Help' started by jegues, Dec 19, 2010.
  1. jegues
    Sep 13, 2010
    735
    43
    See figure attached for problem statement as well as my attempt.
    This is an old midterm for an course I'm going to be taking next term and I thought I'd give it a crack to see if I can get ahead.
    I think I was able to accomplish part a of the question but part b I have some confusions about.
    What is a "single-ended amplifier"? Also, how does one have a negative gain?
    Hopefully after I figure those two things out I can work out a solution.
    Thanks again!
  2. guitarguy12387
    Apr 10, 2008
    359
    12
    Single ended amplifier is the opposite of differential amplifier (to use laymans terms haha!) Basically, you have one signal referenced to ground rather than taking the difference of two signals, which would be a differential amplifier.
    Negative gain = 180 degrees phase shift
  3. guitarguy12387
    Apr 10, 2008
    359
    12
    Also, your work is a little hard to follow (i.e. what is R2, R1). But i think you probably want to choose values for the resistors, not node voltages.
    I'm guessing part b is asking you to find the circuit topology that implements the gains. (I.e. single ended inverting/non inverting amps)
  4. jegues
    Sep 13, 2010
    735
    43
    So what does this mean in terms of a transfer function?
    In a differential amplifer we see,
    \frac{R_{2}}{R_{1}}(v_{2}-v_{1})
    You're saying it's the opposite, so is it
    \frac{R_{2}}{R_{1}}(v_{2}+v_{1})
    If one signal is referenced to ground (let's say V1) then it should be,
    \frac{R_{2}}{R_{1}}(v_{2}-v_{1}) = \frac{R_{2}}{R_{1}}(v_{2}-0) = \frac{R_{2}}{R_{1}}v_{2}
    Are any of these correct?
  5. t_n_k
    Mar 6, 2009
    5,448
    783
  6. jegues
    Sep 13, 2010
    735
    43
    That definatly has alot of information but I still don't know how connect the given terms to make a single ended amplifier with -1V/V gain.
  7. guitarguy12387
    Apr 10, 2008
    359
    12
    Try grounding one of the inputs
  8. jegues
    Sep 13, 2010
    735
    43
    Didn't I do that in the post above? V1 was set to 0v.
  9. guitarguy12387
    Apr 10, 2008
    359
    12
    No i meant that differential = difference of two where single ended is not the difference. It has a single input wrt gnd, not difference btw two signals.
    Yeah, sorry i didn't check that before. Looks right to me though. Depending which input you ground gives inverting or non-inverting.
    I don't konw what you are designating as R2 and R1 though. All Rs are the same in the schem you gave.
  10. guitarguy12387
    Apr 10, 2008
    359
    12
    HINT: changing the ratio of the series to shunt resistors is what gives you different gains. Since they are the same in the given plot, that is why it is unity gain.
  11. guitarguy12387
    Apr 10, 2008
    359
    12
    That is a pretty confusing way to put it. That only makes sense when dealing with sinusoids. DC doesn't have phase.
    You want to think in terms of amplitude and phase. To say that you measure -5v from 1v input seems to suggest that the amplitude is somehow negative. In fact, this is not the case.
    For clarity, if you have an amp with gain of -1, the amplitude of the input AND output will be 1 but the output will be 180 degrees out of phase from the input. Use the frequency domain to get the whole story.
  12. shteii01
    Feb 19, 2010
    3,500
    511
    Yes, I see what you mean.
