single core cable(jumper)
Discussion in 'General Electronics Chat' started by xw0927, Mar 2, 2011.
  1. xw0927
    Dec 19, 2010
    114
    hello everyone,
    I got a simple question... May I know what is the voltage rating of single core cable, the 1 we usually use as a jumper?
    How large the voltage it can withstand?
  2. Kermit2
    Feb 5, 2010
    3,850
    965
    That depends on the type of outer insulator used.
    usually 300 volts is the rating of buss wire used as a jumper on circuit boards.
  3. mcgyvr
    Oct 15, 2009
    4,791
    975
    Maybe he meant "jumper" cable wire?
    You need to consult the datasheets of the specific wire or type of wire you have. There are only thousands of different wire types/insulations,etc..
