Hi After some advice here i have not built circuits in over 12 years so bit rusty.
what im trying to do is use a single push button to trigger a series of events, i was thinking a logic circuit is the best way to go and more reliable for long lasting.
1st push latches the output 1 to give 12v via a relay
2nd push & hold Holds output 1 at 12v until released also done via a relay
3rd push removes the latched output 1
on the 1st push i will also require a LED to trigger
i have seen a circuit on here similar to what i want to do using relays but not quite what im after
can anyone advise
Cheers
Andrew
can anyone advise
Cheers
Andrew
