single 9v supply for + & - 5v regulator
Discussion in 'The Projects Forum' started by childs72, Mar 30, 2006.
  1. childs72
    Jul 3, 2005
    22
    is there any circuit or component that may regulate 9v input to both +5v and -5v output at the same time? i need it to drive my op amp. thx.
  2. windoze killa
    Feb 23, 2006
    605
    24
    TI (Texas Instruments) have a power module and I think the number is PT5022. This will take a +5V input and provide a -5V output. If you make a standard power supply to provide +5V and use one of these modules you should be right.
  3. fognight
    Mar 29, 2006
    Well I am looking at this upside down. Are you married to the particular opamp you have? Will your design allow you to change to a single supply opamp such as an LM324?
  4. childs72
    Jul 3, 2005
    22
    thx for d PT5022 suggested, however it is still a bit expensive for my project...
    by the way my project cannot use single supply op-amp, it is a precision current sink and a precision current source.
  5. Spoggles
    Dec 2, 2005
    67
    If you are not overly concerned about power 'hogging' and if your DC offset requirements are not overly critical , you may want to consider using a voltage divider for your 1/2 vcc voltage source. Make the divider so it draws more current than the rest of your circuit, and of cource use bypass caps.
    Another thing you may want to do if you can, is to use an opamp as the power source for your 'signal ground' (4.5v)... this would be much more efficient than a voltage divider.
    Spoggles
  6. windoze killa
    Feb 23, 2006
    605
    24
    Not if you request samples from TI.
  7. mozikluv
    Jan 22, 2004
    1,437
    hi,
    maybe you might want to consider using a 555 timer with a 5v zener at its output to come up with a -5vdc. :D
    moz
  8. windoze killa
    Feb 23, 2006
    605
    24
    Another option could be to use a MAX232 RS232 convertor chip. These generate their own -5V which you could probably use.
