Sine wave
Discussion in 'The Projects Forum' started by Teena123, Apr 20, 2013.
  1. Teena123
    Nov 22, 2012
    38
    This is something i just thought of, how is it that an internal combustion engine produces a sine wave instead of a square wave??
  2. atferrari
    Jan 6, 2004
    2,670
    785
    Measured where?
  3. blah2222
    May 3, 2010
    565
    33
    Though I do not much about engines, I believe that it works under the same principal as generators and pretty much anything used to create electricity from a kinetic energy.
    If you look at how the generator parts in the engine are moving, you notice that they are rotating in a circular path. The movement is not an abrupt back and forth jerk where there is little time spent in transition between the two points.
    If the electricity generated was in the form of a square wave, the latter jerky motion mentioned would need to be performed, which is not the case in these engines. They have a nice smooth rotation.
    Hopefully that made sense...
  4. aws505
    Member
    Mar 11, 2013
    59
    7
    If you're using a motor to generate AC, you're usually circulating a conducting loop in a field generated from a permanent magnet. blah2222 is correct, here. For more details check out the following links:
    Hyperphysics Explains how motors generate AC. To understand the previous link, you'll need to first have a healthy understanding of Lenz's Law and Faraday's Law.
  5. mlog
    Member
    Feb 11, 2012
    276
    36
    You need to explain yourself. I haven't a clue what you mean.
  6. crutschow
    Mar 14, 2008
    13,508
    3,385
    A generator generates the desired sine-wave voltage because the windings are arranged to do that. It's not intrinsic to rotary motion. Some Stirling engine generators, designed to operate from a solar heat source, have a reciprocating AC sine-wave generator driven directly from the piston with no rotary generator motion at all.
    An engine can have rotary motion but that has nothing particular to do with sine-waves.
  7. vk6zgo
    Jul 21, 2012
    677
    85
    But,in normal practice,a conventional generator (actually alternator) is designed to be rotated.
    Luckily,this rotation is a byproduct of the engine's primary purpose which is to produce smooth rotary motion of its drive shaft.
    The engine's flywheel smooths out the reciprocating mechanical energy supplied by the pistons.
    OP,it may be good idea to Google for "Internal Combustion Engine",
    "Otto Cycle",or similar subjects.
  8. WBahn
    Mar 31, 2012
    18,089
    4,917
    It is a natural consequence of harmonic motion, be it rotational or linear. To get anything other than a sine wave (intentionally) is more difficult.
  9. t_n_k
    Mar 6, 2009
    5,448
    783
    I assumed the OP was referring to the piston displacement [w.r.t time] in the standard IC engine as being sinusoidal in nature.
  10. WBahn
    Mar 31, 2012
    18,089
    4,917
    In that case, it's not sinusoidal. Even if we assume a uniformly rotating crankshaft. As the stroke increases the approximation to sinusoidal motion improves.
  11. wayneh
    Sep 9, 2010
    12,394
    3,246
    You sure about that? How can it not be?
  12. blah2222
    May 3, 2010
    565
    33
    Referring back to my post, I mentioned rotational motion of a generator because it was a quick example to get the point across to the OP. Of course, a piston moving back and forth linearly makes the case as well.
    The initial question was to distinguish between a sine and square wave. I think you guys are taking this a bit off topic.
  13. THE_RB
    Feb 11, 2008
    5,435
    1,305
    Not the stroke increasing, but the length of the connecting rod. As the connecting rod approaches infinity length, the piston motion approaches a pure sine.
  14. wayneh
    Sep 9, 2010
    12,394
    3,246
    Oh, I think I see the point that WBahn was making. And yes, we've hijacked the OP's thread off course.
    #12 likes this.
  15. WBahn
    Mar 31, 2012
    18,089
    4,917
    You are correct. I mispoke and meant the length of the connecting rod, not the stroke.
  16. WBahn
    Mar 31, 2012
    18,089
    4,917
    I don't know if we have or not because I still can't tell what the OP's actual question was about. Is WHAT as sine wave instead of a square wave?
  17. BillB3857
    Feb 28, 2009
    2,402
    348
    Wouldn't the pistons exhibit a linear, reciprocating motion with a velocity profile exhibiting a sinusoidal nature.
  18. WBahn
    Mar 31, 2012
    18,089
    4,917
    An approximation to a sinusoidal profile with the approximation imrpoving as the ratio of the connecting rod length to the stroke increases.
  19. wayneh
    Sep 9, 2010
    12,394
    3,246
    The x-axis position of the crankshaft rod bearing is a sinusoid, since it's rotating evenly through a circle, but the rod is not horizontal unless it's infinitely long, so there is a sight deviation from sinusoid for the piston end of the rod.
