Sine Wave PWM Generator IC?
Discussion in 'The Projects Forum' started by Steven C Lee, Feb 5, 2009.
  1. Steven C Lee
    Feb 5, 2009
    Hi All,
    I am designing a "Inverter" for DC to AC Converter, Which input is 12V DC and Output is AC120V / 60 Hz (1 Phase).
    For Simplify the circuit, I am looking for an ASIC that can generate PWM signals to driver MOSFET dircetly and come out 60Hz Sine Wave AC.
    Is there any information about the ASIC that I am looking for?
    Thanks in advance for your sharing.
  2. Audioguru
    Dec 20, 2007
    9,411
    896
    Not enough pure sine-wave inverters are made to have an ASIC made for them.
    Chinese pure sine-wave inverters use two TL494 PWM controller ICs. One is in a high frequency oscillator that drives Mosfets and a small ferrite stepup transformer. The other TL494 makes the PWM that drives high voltage Mosfets.
  3. Steven C Lee
    Feb 5, 2009
    Hi All,
    I am great to find a IC for SPWM (Sine-Wave PWM) generator.
    It is HEF4752V.
    But this IC can generate 3 phases SPWM signals with 120 degree lag from each other.
    I only need 1 phase of SPWM, May I only use one group of the SPWM signals for my application.
    Is there any concern that I should take?
    Any feedback is appreciate.
  4. derar-z
    Feb 13, 2009
    I am electrical engineering student, a fifth the age of graduation and the draft of your project using the same ic possible to tell a more
  5. derar-z
    Feb 13, 2009
    i can heelp you and you can heelp me and
    I have a full outline for this inverter using ic hef 4752v​
