sine wave generator
Discussion in 'General Electronics Chat' started by lovlyman3030, Nov 22, 2009.
  1. lovlyman3030
    Apr 28, 2008
    10
    hi all im trying to build a circuit to get a 50hz sine wave. i used a generator chip icl 8031 but it gives me a dc offset and i need a pure sine wave with zero offset. i used a single capacitor to block the dc but it shows again after i connect it to an invertor.:( do anyone have any idea hot to generate a pure sine wave using simple circuit and easy one to build?
    thanks all
  2. lovlyman3030
    Apr 28, 2008
    10
    by the way i forgot to mention that i need 2 V peak to peak amplitude :)
  3. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    Post your circuit schematic as it exists.
    Without a schematic, it will take a very long time to get a meaningful reply.
    For schematic images, .png format is preferred.
  4. lovlyman3030
    Apr 28, 2008
    10
    the problem that i dont have a schematic for any circuit it can do the job for me that's what im looking for so if you have a schematic for any circuit can do that please share it by the way im using it for a power senior project (statcom) which i need to build.
  5. t06afre
    May 11, 2009
    5,939
    1,222
    I agree with the other. Post a schematic of the circuit you have so far. You have already built something so you must have a schematics. It does not matter if it is crude.
  6. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    You need to post as schematic diagram of the circuit as it currently exists.
    The ICL8038 (which I believe you meant to type instead of ICL8031) has a high-impedance output (about 1k). If you want for it to have more drive current, you will have to use a voltage follower/buffer arrangement.
    But until we see your schematic, we won't have any idea how much current your voltage follower/buffer will need.
