Hello! I am used to the software and aerospace world, and only have an intermediate level of knowledge in electrical circuitry. I have been creating a few simple circuits to help improve my knowledge here.
The circuit I've been working on is a simple sine wave generator based on a Wien Bridge Oscillator and Op Amp, using a JFET for automatic gain control. This part of the circuit has been working correctly after choosing an Op Amp with a higher bandwidth product and slew rate. At low frequencies it outputs decent voltage, but by 35 kHz it only outputs about 60mV. I believe this is to be expected, so I thought I'd correct it with a non-inverting Op Amp to boost it to my 9V design point.
This non-inverting amplifier portion is where behavior is not quite what I am expecting. I am using an OPA552 because of its high bandwidth and slew rate, as well as decent current output ability. It appears to have very little gain at 35 kHz, however. Looking at the data sheets, I should be getting at least 50 dB of gain in an open-loop configuration. This seems to be enough, but the most I seem to be getting with both closed- and open-loop configurations is only about 23 dB (or G=15) to about 1V. The Gain Bandwidth Product is 8 MHz, so I would assume that I should at least be able to get G=200+ at 35 kHz.
If I pre-amplify the signal to about 1V and then feed it into the OPA552, I hardly get any gain at all. The output signal regardless of the resistor values is barely above the input of 1V. Am I missing something obvious in how Op Amps work? Or do I simply need an even higher speed Op Amp for these frequencies?
I've included a schematic of the non-inverting amplifier I am using. It's no different than the standard ground and feedback resistor design. I have tried resistor values ranging from (R_feedback = 1k, R_g = 6.8) to (R_feedback = 220k, R_g = 1k) and (R_feedback = 10k, R_g = 1k). None of these seem to provide any better behavior. I can post the Wien Bridge circuit if needed as well, but I'm not sure if that part of the circuit should matter. Not included in the schematic are the sets of decoupling capacitors (0.1uF and 10uF) bridging +V, -V to ground.
