Sine Wave distortion measurements
Discussion in 'General Electronics Chat' started by Wendy, Nov 12, 2009.
  1. Wendy
    Thread Starter Moderator
    Mar 24, 2008
    20,772
    2,540
    Way back when I used a piece of HP equipment to measure distortion of a sine wave. It was fun to use, but long gone.
    How would a hobbiest measure distortion of a sine wave? It can look good on a oscope and still be pretty bad.
    One thought is to take the waveform in question, filter it though several low pass filters to create a reference (without phase shifting it), invert it, and null it with op amps. What is left is the distortion.
    Anyone seen a home brew setup to do this? With all the audiophiles out there I suspect it exists.
  2. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    I don't know how you could run a signal through several low pass filters and not get at least SOME phase shift, just due to propagation delays alone.
    [eta]
    Just a thought - wind yourself a broadband 1:1 isolation transformer using a quality ferrite toroid. Use the output of the transformer to drive the y-axis of your o-scope, and the input signal for the x-axis. If there is no distortion and no losses, you should get a perfect circle on the 'scope.
  3. Wendy
    Mar 24, 2008
    20,772
    2,540
    Any imperfections in the circle being distortion?
  4. studiot
    Nov 9, 2007
    5,005
    515
    It is often overlooked that to get meaningful measurements on low value distortion you require a very low distortion signal.
    The "poor man's" way is to use spot frequencies. Both the generator and the filter can be finely tuned, twinTEE being the frequency defining network of choice, although I have seen the Wein used as well.
  5. Wendy
    Mar 24, 2008
    20,772
    2,540
    The old HP equipment (don't remember it's model number) you adjusted for a in the meter, then flipped the switch to automatic, and it would tune itself to the waveform. My shop used it to check the quality of amplifiers in milspec equipment.
    I think it was a precursor to a selective voltmeter.
  6. KL7AJ
    Nov 4, 2008
    2,047
    295
    Howdy!
    The traditional distortion analyzer was pretty straightforward. It had a NULL circuit for notching out the fundamental frequency (a modified Wheatstone Bridge). You'd then measure alll the remaining power, which was all the harmonics, if any. Although you couldn't separate the diffferent harmonics, it was usually THD you were looking for.
    With FFT analyzers, you can get a lot more detail, of course.
    If you have an idea ahead of time as to what the harmonic content might be, you could also use a null-type analyzer on those particular harmonics and eliminate them, one at a time.
    Eric
  7. KL7AJ
    Nov 4, 2008
    2,047
    295
    I might add that with a trained eye and a good oscilloscope, you CAN see harmonic distortion down to about 1%.
    eric
  8. Externet
    Nov 29, 2005
    780
    58
    For a signal generator, I don't know. For an amplifier, try an oscilloscope channel A at input, channel B at output, invert B if not inverted output, and select A+B.
    Adjust channel gain for minimum amplitude reading at maximum magnification. It may need adjusting delay setting. Will yield a qualitative waveform, not a % reading.
  9. studiot
    Nov 9, 2007
    5,005
    515
    The thing to do to eyeball it in a scope is to use a dual channel.
    Input the signal input to the amp into one channel
    Take the output from the amp through a sharp filter to remove this frequency and amplify what's left 1000 or 10,000 times in the second channel.
    You can see the distortion this way.
  10. Wendy
    Mar 24, 2008
    20,772
    2,540
    Sorry, no dual channels here. X and Y maybe, but have I mentioned how old my oscope is?
    Another thought occurs, the PC sound card oscope can also be used as a spectrum analyzer, so I've heard.
  11. Audioguru
    Dec 20, 2007
    9,411
    896
    You can feed any signal (even a square-wave) into a switched-capacitor lowpass filter IC and get a low distortion sine-wave output.
    My extremely low distortion sine-wave generator uses an over-sampled stepped sine-wave made from a CD4018 and a few resistors and an 8th-order Butterworth lowpass filter IC. My distortion analyser uses a switched-capacitor notch filter IC that uses the same clock as the generator so they track.
  12. KL7AJ
    Nov 4, 2008
    2,047
    295
    Yes, the FFT analyzer built into GoldWave is really very good. And Goldwave is FREE!
    You can also use a ramp generator to check linearity...but you need to know if your scope is linear first! (Old rubber yardstick syndrome!)
    eric
  13. Wendy
    Mar 24, 2008
    20,772
    2,540
    OK, this I know, but how do you measure the numbers?
    What's driving this is simple enough, how do you know when you have a good design?
    Made ya'll think at least. I'm not sure I would buy that old HP equipment if it was available, but it would be tempting.
  14. studiot
    Nov 9, 2007
    5,005
    515
    Well it doesn't have to be dual. You can just measure one, then the other.
  15. Audioguru
    Dec 20, 2007
    9,411
    896
    Rectify and filter the input sine-wave. It is the reference.
    Adjust the rectified and filtered output level so its DC signal is the same level as the input DC reference signal.
    Then rectify and filter the output with the fundamental notched out. Its level is the percentage of noise plus distortion.
  16. THE_RB
    Feb 11, 2008
    5,435
    1,305
    I would try recording it into your PC sound card which is 16bit, then look for some free software to analyse it. It would be easy enough to write a VB application etc to analyse the sound data, wave files are very easy to read, but I would be surprised if there is not already a free app out there to do it.
  17. Wendy
    Mar 24, 2008
    20,772
    2,540
    Probably. I like AudioGuru's notch idea, it is simple, and I'm betting that is how HP did it.
    The spectrum analyzer would also be an interesting approach, though getting numbers out of it would be hard. It would let you tweak a wave shaper for the best waveform.
    I wouldn't bother recording it, you can do this stuff real time if I'm not mistaken. I think the sound card makes a questionable oscope, but it definately has its uses.
  18. studiot
    Nov 9, 2007
    5,005
    515
    It should be remembered that most THD instruments actually record THD + Noise.
    Switched capacitor filters have two difficulties that have to be overcome at the expense of circuit complexity. This is not a problem for an IC manufacturer, but extra work for a one-off designer.
    These problems are:
    1) Keeping the switching noise out of the measurement.
    2) Achieving appropriate impedance levels presented to the source.
    I still maintain that for the average amateur analog based spot frequency measurement is the way to go.
  19. Audioguru
    Dec 20, 2007
    9,411
    896
    The switching noise of modern switched capacitor filter ICs is very low and is 100 times the cutoff frequency so is easily filtered out.
    An opamp buffer isolates the fairly low and changing-with-frequency input impedance of a switched capacitor filter IC.
  20. studiot
    Nov 9, 2007
    5,005
    515
    Yes Guru I agree both those points are true.
    All I said was you have to take them into account if you use an SCF.
    Incidentally you need a special op amp to do the buffering so as not to introduce distortion from your equipment.
