Greetings,
I am working in a project that I need to develop a SPWM Inverter for an induction motor or an UPS.
Few days ago, I started to develop a small program that uses a sine lookup table and the PWM peripheral to generate the SPWM pulses in the PWML1 and PWMH1 pins of an dsPIC33FJ32MC202.
The sine lookup table comparison are not yet implemented. I am currently using this code to just test the PWM pins of the dsPIC.
However, when I simulated my code in the Proteus ISIS nothing happens and unfortunately I am quite new to the dsPICs. Here is my current code.
Any ideas what is wrong, please? The PWMH1 and PWML2 pins should be pulsing...
Thanks,
FBorges22
Rich (BB code):
#include <p33FJ32MC202.h>
_FOSCSEL(FNOSC_FRCPLL) // configures the fast oscillator with PLL
_FOSC(FCKSM_CSECMD & OSCIOFNC_ON) // enables only clock switching and digital I/O
_FWDT(FWDTEN_OFF) // disables the watchdog timer
_FPOR(FPWRT_PWR1) // disables the power on reset
_FICD(ICS_PGD2 & JTAGEN_OFF) // disables the JTAG and the ICS
#define OC5_IO 22 // define OC5 output function number for PPS
unsigned char sine[42]={0,9,19,28,38,47,57,66,75,84,93,102,111,120,128,136,144,152,160,167,174,181,188,194,200,206,211,217,221,226,230,234,238,241,244,246,249,251,252,253,254,254};
unsigned char pwmFHtimes; // PWM frequency hopping times, it is based on PWM cycle
void MCU_init(void)
TRISB=0x00; // PORT B as output
RCONbits.SWDTEN=0; // Disable Watch Dog Timer
pwmFHtimes=0;
OC1CONbits.OCM=0; // Output compare channel is disabled
OC1R= 0x0099; // Initialize Compare Register1 with 50% duty cycle
OC1RS= 0x0099; // Initialize Secondary Compare Register1 with 50% duty cycle
OC1CONbits.OCSIDL= 0; // Output capture will continue to operate in CPU Idle mode
OC1CONbits.OCFLT= 0; // No PWM Fault condition has occurred (this bit is only used when OCM<2:0> = 111)
OC1CONbits.OCTSEL= 0; // Timer2 is the clock source for output Compare
OC1CONbits.OCM= 0x6; // PWM mode on OC, Fault pin disabled
PR2= 0x0132; // Initialize PR2 with 0x0132 = 0d306 as PWM cycle
IFS0bits.T2IF=0; // Clear Output Compare interrupt flag
IEC0bits.T2IE=1; // Enable Output Compare interrupts
T2CONbits.TON=1; // Start Timer2 with assumed settings
int main (void)
while(1)
Idle();
return 0;
void __attribute__ ((__interrupt__, no_auto_psv)) _T2Interrupt(void)
IFS0bits.T2IF = 0;
if (++pwmFHtimes == 5)
// every 5 cycles for update
pwmFHtimes = 0;
// update the duty cycle for PWM
if (OC1RS == 0x0099)
OC1RS = 0x00E5; // 75% duty cycle
else
OC1RS = 0x0099; // 50% duty cycle
Thanks,
FBorges22
