sine or square wave generator
Discussion in 'The Projects Forum' started by rashid89, Jul 16, 2013.
  1. rashid89
    Jul 16, 2013
    hello guys,
    i love electronics but i don't have much better skills in electronics...:confused:.
    kindly help me to make a sine or square generator....
    the input for generator is 12 volt dc (car battery) the generator should be from 10 volts to 25 volts and the current should be from 4 amps to 10 amps.....
    kindly help me to build this circuit......i don't have enough skills to built it.
    kindly give the circuit diagram and components list
    thanks in advance.....
  2. t06afre
    May 11, 2009
    5,939
    1,222
    A car battery is about 12 volt. So how do plan to get 25 volt out. And 4 to 10 ampere output not a small load. What you plan to do can be done but it will be quite complicated not a beginner task. What are you trying to? You should start by telling us that. Then it is small chance we will be able to help you. But none of us have a magical circuit wand
  3. BobTPH
    Jun 5, 2013
    807
    121
    I'd love to know what the application is that either a sine or square wave would work equally well.
    Bob
  4. shortbus
    Sep 30, 2009
    4,098
    1,697
    Is that HHO I smell? :)
  5. wayneh
    Sep 9, 2010
    12,405
    3,256
    Just get an automotive audio amp and input whatever wave shape you want using an iPod.
