simultaneous conduction
Discussion in 'General Electronics Chat' started by TAKYMOUNIR, Nov 10, 2011.
  1. TAKYMOUNIR
    Thread Starter Active Member
    Jun 23, 2008
    351
    how can avoid the effect of simultaneous conductin in FET (AND IF SOME ONE KNOW GOOD LINKS TALKING ABOUT IT CAN SEND ME THE LINK PLEASE
    THANKS
    How can i make the fet turn on and off fast i need the rise and fall time less than 1 micro second
    thanks
    How can i drive mosfet fast i need rise time and fall time less than 1 micro second
    thanks
  2. praondevou
    Jul 9, 2011
    2,936
    489
    Please tell us what FET you are talking about and what driver u are using.
    Cross-conduction can be avoided by an appropriate deadtime.
    The time it takes to charge the gate depends mainly on the gate charge Qg, the lead inductance, gate/source wire inductance/length and the driver's current capability.
    TAKYMOUNIR likes this.
  3. shortbus
    Sep 30, 2009
    4,096
    1,692
    Use a dedicated mosfet gate driver chip instead of trying to do it with discrete components.
    Keep the driver as close to the mosfet as possible.
    Use the correct value gate resistor from driver to gate. Values over 50 ohms are usually not correct. Values in Kohms are almost never correct.
  4. TAKYMOUNIR
    Jun 23, 2008
    351
    in general how can i design gate drive circuit
  5. SgtWookie
    Jul 17, 2007
    22,183
    1,728
