Simulator that can actually simulate this?
Discussion in 'General Electronics Chat' started by Zortz, May 2, 2014.
  1. Zortz
    May 2, 2014
    16
    Hey!
    I am starting with electronics and was using Multisim for simulations. I am following Make - Electronics book.
    Multisim is quite nice but now i found a circuit that will not work there.
    The problematic circuit:
    Knowing that people like different simulators i would like to ask you for a favor:
    Could you draw this same example in your favourite simulator and report back here what happens.
    From the results i would like to find simulator that works with these simple circuits.
    Thank you very much!
  2. t06afre
    May 11, 2009
    5,939
    1,222
    Why does this circuit not work you in your simulator? By the way what is your source for this circuit. The circuit do not look coorect as shown. The resistor vaules will ensure that the LED is off no matter with 6 volt DC as supply voltage
  3. Zortz
    May 2, 2014
    16
    Multisim goes crazy, sometimes giving errors other times just stopping the capacitator charging.
    There is a thread in multisim support forums about this and some guys modified it alot to get it working. But i would like it without modifications because it is working in real life why not in simulator?
    Edit: this circuit is direct screenshot from "Make-electronics"
  4. inwo
    Nov 7, 2013
    2,435
    315
    Does simulation allow input for "put"?
  5. bertus
    Administrator
    Apr 5, 2008
    15,799
    2,385
  6. Zortz
    May 2, 2014
    16
    I made picture of multisim. This is how it gets stuck and nothing happens anymore:
  7. Alec_t
    Sep 17, 2013
    5,968
    1,135
    Just about works as is in LTspice, depending on choice of LED model. Works better, and less dependent on LED type, if 15k is replaced by higher value, e.g. 22k.
  8. RichardO
    May 4, 2013
    1,336
    429
    Just curious... Where did you get your PUT model?
  9. Zortz
    May 2, 2014
    16
    Thank you for the results!
    I tested 22k in multisim and it is working also. Quite small drift from the real circuit so i think it is acceptable.
    However still wondering why it is not working as is and how can LED type make any difference here?
    Thanks!
  10. Alec_t
    Sep 17, 2013
    5,968
    1,135
    Free download from Yahoo LTspice User Group.
    RichardO likes this.
  11. Alec_t
    Sep 17, 2013
    5,968
    1,135
    Transistor gain? Junction forward voltage drop? Leakage current? ....?
