Simulator Program for Electronic Circuits
Discussion in 'General Electronics Chat' started by bhaazee, Jun 3, 2012.
  1. bhaazee
    Mar 3, 2012
    19
    Although this topic is often discussed in here, I would like to know if there is any software where I can simulate the flow (how the signal, current, voltage flows) in electronic circuits (similar to labview)?
    Regards
  2. t06afre
    May 11, 2009
    5,939
    1,222
    Labview is a programming language. That use flow of data as principal. Many in this forum use the free LT-spice(just use Google) for circuit simulation. LT-spice can do simulations from a drawn circuit.
  3. arunskumar05
    Nov 1, 2011
    18
    circuit wizard is a good and simple software,
    where u can simulate how the signal, current, voltage flows in electronic circuits
  4. Austin Clark
    Dec 28, 2011
    409
    44
    This is an EXCELLENT piece of software, and it's in Java so it's very cross-platform.
  5. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    If you have Java installed, you can use the online Falstad circuit simulator:
    http://www.falstad.com/circuit/
    It's pretty handy for demonstrating current flow and voltages in a limited manner.
    If you want something more accurate, or something that you can add PSPICE models to, you'll need to go to something like LTSpice.
  6. bertus
    Administrator
    Apr 5, 2008
    15,801
    2,387
  7. bhaazee
    Mar 3, 2012
    19
    Thanks everyone for your suggestions.
    I don't understand the purpose of Fritzing (Just useful for building the circuits. Not suited for simulation)
    btw, I would like to add "Everycircuit Free" from Android Market. Looks simple to use and easily understandable (I have no profound knowledge in electronics). But, still needs improvement.
  8. mcgyvr
    Oct 15, 2009
    4,791
    975
    I second LTspice..
