simulation software
Discussion in 'Electronics Resources' started by Shane7, Jun 18, 2012.
  1. Shane7
    Jun 18, 2012
    I need to simulate a power electronic circuit of a battery charger for my project. what will be the most suitable software for this? will a free student version sufficient for the task? (circuit contains LM350 and LM741)
  2. RRITESH KAKKAR
    Jun 29, 2010
    2,831
    89
    lt SPICE IV...................
  3. DMahalko
    Oct 5, 2008
    180
    14
    LTspice lacks any models for switches ... very odd.
    TINA-TI has switches and the LM741, but I'm not seeing the LM350.
    PSpice, TINA-TI Reference Designs and Spice Models
    http://www.ti.com/adc/docs/midlevel.tsp?contentId=55102
    It seems like there's always some problem with free tools. Though not enough problems for me to want to pony up some cash for a professional tool. ;)
  4. crutschow
    Mar 14, 2008
    13,505
    3,378
    LTspice does have a voltage controlled switch (SW).
  5. PUNIT_BHAI
    Nov 11, 2009
    Tina pro,pcb wizard,proties
  6. t06afre
    May 11, 2009
    5,939
    1,222
    I do not use LTspice myself. But does not LTspice allow the use of external/imported spice models? You can not expect a simulator to have every component in the library. So the skill to import other spice models are important
  7. knowone
    Aug 24, 2009
    Shane7. Give us your circuit and we can try to see
    what can be found.
    I have used Paul Falstad "circuit"
    to simulate a 240Vac to 12V dc regulated.
    To what level are you working?:D
    LTSpice is pretty good, for free.
    I use Tinycad for my schematics, also free.
    Take care.
  8. absf
    Dec 29, 2010
    1,493
    374
    My proteus simulator dont have LM350 (3A) but it has LM317K and LM317T which I think is similar to LM350 except the current is only 1.5A. Would that be OK with you?
    You can get the demo version of proteus from Labcenter UK here
    http://www.labcenter.com/products/vsm_overview.cfm
    Allen
