simulation software
Discussion in 'Embedded Systems and Microcontrollers' started by cpleng7, Oct 1, 2010.
  1. cpleng7
    Thread Starter Active Member
    Dec 18, 2008
    120
    did anyone in here know any software can do simulation between PIC microcontroller with the three phase induction motor?
  2. retched
    Dec 5, 2009
    5,201
    313
    matlab+simulink can simulate/emulate particular PIC uC's and induction motors.
  3. Potato Pudding
    Jun 11, 2010
    684
    92
    I think Proteus might be able to handle that.
  4. cpleng7
    Dec 18, 2008
    120
    can you give more information on here?
    I have try the proteus software it cannot works
  5. retched
    Dec 5, 2009
    5,201
    313
    Matlab allows you to model different load types (inductive, resistive) in different states (AC or DC motor, transformer, heater, switched) and incorporates the resulting transients into the simulation.
    You can write code for the PIC and handle it just as you would real life, and connect it to the FETs, or IGBTs to the load.
    It will allow you to follow temperature and electrical changes in the devices running under normal conditions or you can add abnormal loading or failing conditions to simulate how the devices will react.
  6. cpleng7
    Dec 18, 2008
    120
    thanks retched, can you suggest me any references that I read?
  7. retched
    Dec 5, 2009
    5,201
    313
