simulation software for electronics
Discussion in 'General Electronics Chat' started by Shayan22h, Dec 7, 2012.
  1. Shayan22h
    Oct 24, 2012
    30
    hey guys i have one very short question, well I do have the 2 softwares of multisim and proteus and know how to work with them, my problem is I am looking for LM2917 frequency to voltage convertor, proteus has a 12 pins version but i need a 8 pin version so I was wondering there could be a software to have this component with 8 pins :)
    thanks in advance .
    cheers,
  2. crutschow
    Mar 14, 2008
    13,509
    3,385
    If you are just simulating the software then the pin count doesn't matter.
    If you need the 8-pin version for a PCB layout then you may need to generate that footprint yourself.
  3. Shayan22h
    Oct 24, 2012
    30
    well thanks for ur reply :) but for me does matter cuz i cant convert the 12 pin to 8, unfortunately in the LM2907 datasheet there is a circuit schematic [ frequency to voltage convertor] for the 8 pin
    cheers ;)
  4. tshuck
    Oct 18, 2012
    3,531
    675
    Your point being? Just hook up the 12-pin version like you see the 8-pin version is....
  5. Shayan22h
    Oct 24, 2012
    30
    well i attached the 8pins from the datasheet and the 12 pins which i tried to build, inspired by the one from datasheet so could u please take a look at it if it is ok ?
    cheers, :)
  6. tshuck
    Oct 18, 2012
    3,531
    675
    That looks good to me....
    Shayan22h likes this.
