Simulation error
Discussion in 'General Electronics Chat' started by Dritech, May 7, 2014.
  1. Dritech
    Sep 21, 2011
    756
    5
    Hi all,
    I am using the OPA337PA op-amp in a simulation circuit. When running the simulation, I am having the attached errors. Why is this happening please?
    When I replaced the OPA337PA with the OPA340PA the errors did not occur. What is the main difference between these two ICs?
    Thanks in advance.
  2. tshuck
    Oct 18, 2012
    3,531
    675
    The simulator was unable to resolve all of the related calculations within the specified iterations to within the specified tolerances.
    Changing your simulation accuracy/speed/convergence/iterations parameters should help.
  3. crutschow
    Mar 14, 2008
    13,475
    3,361
    You can also try using the Transient Simulation options of "Start external DC supply voltages at 0V" or "Skip initial operating point solution".
