Simulating / Plotting Output Impedance in SPICE
Discussion in 'General Electronics Chat' started by newbie217, Jan 31, 2011.
  1. newbie217
    Thread Starter Active Member
    Apr 12, 2009
    52
    I'm trying to figure out how to plot, simulate and calculate the output impedance (rds) of a simple, diode-connected NMOS.
    I'm using the following model:
    .model MBREAK2 NMOS (w = 5u l = 1u vto = 0.7 kp = 110u gamma = 0.4 lambda = 0.04 phi = 0.7)
    1) I set the DC bias = 1.0 V and run a transient simulation to obtain the bias currents, voltages.
    2) I see that the transistor is in saturation, and use the following equation: gm = 2ID / (VGS - VT) = 2(25.74 uA) / (1.0 - 0.7) = 0.172 mS. I can see my hand calculation matches the simulation number.
    3) The textbook says ro ~= 1/gm. 1/0.172 mS = 5.8 k. Is this how to calculate rds? How do I simulate / verify this information?
    4) Lastly, I'm still confused about static resistance vs. dynamic resistance. I ploted some data points and used: (V2-V1)/(I2-I1) in one column and simple V/I in the other column. For small changes to the bias point, is this the change reflected on rds? What does the static resistance V/I tell us? How can I simulate this?
  2. newbie217
    Apr 12, 2009
    52
    I left out ro = 1/(lambda*ID) = 1/(0.04 *25.74 uA) = 971k. Not sure how to relate this information w/ the above calculation :confused:
