Simulating Input Offset Voltage (Spice)
danielb33
Joined Aug 20, 2012
105
I want to simulate an input offset voltage in a spice simulation.
I have the following circuit...
If I add 1.25mV to the non-inverting terminal, is this the same as adding an input offset?
34,469
Yes.
It can be added to either (but only one) terminal.
But note that many spice op amp models already include an input offset.
Run the simulation for the op amp as a non-inverting follower with the input grounded and see what output offset is indicated.
