Hello
I've recently installed LTspice in order to try and simulate a simple buck-boost converter. From this simulation, I wanted to see the chaos properties that could be seen when changing around some parameters in the circuit i.e. the threshold current, resistor value and so on.
I want to simulate a buck-boost converter where the switch is either on or off depending on the current that flows through the coil and the clock frequency for the switch. In this instance, when the current flowing through the coil reaches 4A, the switch opens, and when the current through the coil reaches 0 or an increment of time = nT (n being an integer and T being 20μs or anything that would be viable) the switch closes.
However, I seem to be having some trouble figuring out exactly what to put where in order to realize these parameters and simulation. I've tried looking through multiple sites and books, but really only found tutorials on voltage controlled switches.
When trying to simulate the circuit, I get the error 'Multiple instances of "W1"'.
Thanks to anyone who may seem to be able to help.
