simulate low temperature
Discussion in 'General Electronics Chat' started by superway, Aug 10, 2012.
  1. superway
    Thread Starter Active Member
    Oct 19, 2009
    128
    I am looking for a circuitry that can simulate low temperature for battey's mat. This circuit can turn the heat on the mat when temparature is low. We used Freez-it bottle so far, but it is expensive.
    Thanks in advanced
  2. nomurphy
    Aug 8, 2005
    567
    12
  3. praondevou
    Jul 9, 2011
    2,936
    489
    If you have a compressor, you can use a vortex tube. Or you can wait until winter ;). Or you could use a peltier element attached to the sensor.
  4. mcgyvr
    Oct 15, 2009
    4,793
    976
    how low is low?
    Buy a cheap refrigerator?
    most proper thermal chambers use liquid nitrogen LN2 or liquid carbon dioxide LCO2 (use extreme caution)
  5. ErnieM
    Apr 24, 2011
    7,443
    1,628
    Ice cubes?
  6. WBahn
    Mar 31, 2012
    18,093
    4,920
    Hopefully you are getting the idea that it is very hard to give a meaningful answer unless and until you give us some meaningful information to work from. Such as, what temperature range you are talking about, how long you want to hold it at that temperature, and how accurate you want that temperature to be, and perhaps some idea of how much energy is going to have to be pulled away from the object.
