I wrote a code that only thing that is supposed to do is to chose if the IO bus is input or output.
The module has one input vector(data_in), one output vector (data_out), a clk, an output enable(oena) and the IO BUS (data_inout)
above is the code i used:
(source: http://www.altera.com/support/examples/vhdl/v_bidir.html)
I think everything should work fine, but modelsim refuses to simulate this right.
When the IObus is used as output (oena = '0') is doesn't switches to input.
I've also used a much simpler code but it also doesn't work.
Is there a reason for ModelSim to refuse simulating this as expected?
Is there any kind of workaround for this?
Thanks,
Rich (BB code):
entity inoutleon is
port(
oena, clk : in std_logic;
data_out : out std_logic_vector (31 downto 0);
data_in : in std_logic_vector (31 downto 0);
data_inout : inout std_logic_vector (31 downto 0));
end inoutleon;
architecture Behavioral of inoutleon is
SIGNAL a : STD_LOGIC_VECTOR (31 DOWNTO 0); -- DFF that stores
-- value from input.
SIGNAL b : STD_LOGIC_VECTOR (31 DOWNTO 0); -- DFF that stores
-- feedback value.
BEGIN
PROCESS(clk)
BEGIN
IF clk = '1' AND clk'EVENT THEN -- Creates the flipflops
a <= data_in;
data_out <= b;
END IF;
END PROCESS;
PROCESS (oena, data_inout) -- Behavioral representation
BEGIN -- of tri-states.
IF( oena = '0') THEN
data_inout <= "ZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZ";
b <= data_inout;
ELSE
data_inout <= a;
b <= data_inout;
END IF;
END PROCESS;
end Behavioral;
Rich (BB code):
begin
data_inoutleon <= data_outleon when oena = '0' else (others => 'Z');
data_inleon <= data_inoutleon when oena = '1' else (others => 'Z');
end Behavioral;
Thanks,
