i have an old simpson anolog voltmeter. it works but it is a bit wierd. it was working but aprox 1/2 V off even though the scale is calibrated. so i took it apart and there was a clothe wire wound resistor. the wire came off of the one terminal of it so i soldered it back on and it worked ok. but it has 1, 2.5, 5, 10, 25, 50, 100, 250, 500, 1000 V DC. the 1 volt position conects - of the meter direct to - terminal post, all rest use a series of resistors, so the meter mechinism apears to be 1 volt.
the problem is any position under 25 v makes the meter show almost double or triple reedings. but at 25v a lantern battry, 9 volt show up acuratly. i'm thinking its a resistor problem somewhere between 1-10 V. i'm thinking one of the wirewounds for 2.5&5v are shorted out. because else it should have not worked at all with a broke wire. but it shows 1.5 K ohm. i have not found any schematics or any info on it other than posibly a 1951 model. it is a model #377. i would like any sugestions on what value resistors thre should be.
