Simply an equation
Discussion in 'Homework Help' started by Kayne, Mar 23, 2009.
  1. Kayne
    Thread Starter Active Member
    Mar 19, 2009
    I am getting confused with how to simplfy equations i have put an example below and simplified in two ways can anyone tell me if i am correct? Or where i have gone wrong
    ! = NOT
    & = AND
    !A&!B&!C + !B&C&!D + A&C + A&B
    !A&!B(C+!C) +!B&!D + A&C + A&B
    !A&!B + !B&!D + A&C + A&B
    Is this as far as I can go or can
    !A&!B + A&B Cancel out also leaving
    !B&!D + A&C
    Or is this correct way
    Method 2
    !C(!A!B+AB)+!B&C&!D + A&B
    !B + C&!D + A
    if someone can clear this up that would be helpful
  2. Ratch
    Mar 20, 2007
    You have gone wrong several ways.
    1) You have used a clunky, clumsy notation. No one wants to read your equations that way. Try instead A'B'C' + B'CD' + AC + AB .
    2) You have not searched this forum for an answer. Two days ago I answered a similar question.
    3) You have not used a Karnaugh map (K-map). Try it, and you will like it.
  3. thatoneguy
    Feb 19, 2009
    The verilog notation is a matter of preference, without using TeX, getting the equation readable is difficult.
    Here is the TeX version, put the tex and /tex tags around it to make it look like the image below, which is auto-generated when you click Preview or Submit:
    \overline{A}\overline{B}\overline{C} + \overline{B}\overline{C}\overline{D} + AC + AB
  4. Kayne
    Mar 19, 2009
    thanks for the reply and i will start using the notation you have said
