Simplifying boolean expression
Discussion in 'Homework Help' started by angelic_rinoa43, Oct 30, 2005.
  1. angelic_rinoa43
    Oct 30, 2005
    I'm really bad with these and i need some help simplifying something. I need all the work to be shown though, sorry if thats a hassle. Here it is:
    A'BCD+A'BCD'+A'BC'D+A'B'CD+ABCD+ABCD'+ABC'D+ABC'D'+AB'CD+AB'CD'
  2. hadef
    Oct 30, 2005
    actually u r summing the minterm to have sum of product form of two level digital circuit getting it from the truth table that u design
    u need to simplify it because u need less complixity which lead u to less cost of components (logic gates)
    there is two ways either u do the simplification by the k-map or by using the boolean manipulation
    for good digital circuit designer u should use k-map method
    so the answer would be
    DB + AC + A'CD + ABD' + CB
    and the way i did it is uploaded
  3. angelic_rinoa43
    Oct 30, 2005
    I'm just in a beginners digital electronics class and a lot of the stuff you talked about we haven't gone over and it does't make any sense at all to me, i really have no clue what k-mapping is. I feel really stupid and want to switch out of that class but i don't think i can do that until the semester is over.
  4. Dcrunkilton
    E-book Co-ordinator
    Jul 31, 2004
    416
    11
    Solution by Karnaugh map is attached. See Digital volume 4 "Karnaugh Mapping" chapter for more details. Your best bet is to look at the Sum of Products solution only, as it is less complicated. Feel free to Ignore the Minterm, Product of sums at the bottom of the attachment. It is an alternate, less often used form.
    Why do we use karnaugh Maps instead of Boolean Algebra? See intoductory paragraphs to "Karnaugh Mapping" chapter. For more details on the solution method see "Larger 4-variable Karnaugh Maps" section of digital volume 4 "Karnaugh Mapping" chapter
    Y = AB +CD + BD+ BC + AC (Sum of Products solution)
  5. hadef
    Oct 30, 2005
    thank u Dcrunkilton
    for the correction i winder why i always do the same mistake
    i think ur answer is correct
