Simplifying boolean expression inconsistency.
Discussion in 'Homework Help' started by sini, Sep 30, 2011.
  1. sini
    Jun 28, 2010
    6
    Is it possible to simplify algebraically y = !C(!A!B!D + D) + A!BC + !D
    into y = !C + !D + !BA
    If I use the method of transforming the question first into Sum-of-Products form and then entering each term into Kmap I will obtain the above simplification after reading off the 1s, but, if I just use algebraic method instead I can never reach this result and instead produce
    y = !C + !D + !B(!A!C + AC) but by simple truth table it is obvious A =/= XNOR which AC + !A!C is.
    My algebraic derivation:
    y = !C(!A!B + D) + A!BC + !D
    y = !A!B!C + !CD + A!BC + !D
    y = !C + !D + !B(AC + !A!C) as oppose to y = !C + !D + !BA
    I can get the y = !C + !D + !BA result if I put y = !C + !D + !B(AC + !A!C) terms into Kmap and read solution from there, but shouldn't there be a way to arrive at the answer just by using algebra laws?
    Thank you for reading.
  2. Zazoo
    Member
    Jul 27, 2011
    114
    43
    You have:
    Rather than factoring !B, leave it as:
    y = !C + !D + !BAC + !B!A!C
    You can eliminate the fourth term completely since you have !C as the first term, giving:
    y = !C + !D + !BAC
    From here !BAC reduces to !BA (again, because of the !C term). This gives you your K-map answer.
  3. sini
    Jun 28, 2010
    6
    ah, thank you :)
