I am trying to simplify a boolean expression that I have pulled from a K-Map with a "checkerboard pattern". I recall my lecturer saying something about in the case of not being able to group 1s in a k-map, it will always be a XNOR or XOR function, and that if the top left is 1/high/on then it will be XNOR but if it's 0/low/off it will be XOR (lease correct me if I'm wrong, it was a bit of a throw away statement.
The top left in my k-map is a 0.
(Question is: Design a 4-Bit Odd Parity Checker, output is 1 when exactly odd number of inputs (A,B,C,D is on )
I have got down to
A\cdot \overline B \cdot \overline C \cdot \overline D + \overline A \cdot \overline B \cdot \overline C \cdot D + A \cdot B \cdot \overline C \cdot D + \overline A \cdot B \cdot C \cdot D+ A \cdot \overline B \cdot C \cdot D + \overline A \cdot \overline B \cdot C \cdot \overline D + A \cdot B \cdot C \cdot \overline D
I am not comfortable simplifying this kind of thing at all, this is my first year at Uni after 5 years away from school! I think the fact that I don't remember "factoring" in decimal maths is what's holding me back here.
I've been able to solve/simplify much simpler expressions, but this has just stumped me, I don't know where to start and feel like every time I make an attempt I'm just "guessing" my way through it, and going the wrong wrong way about it!
I just need someone to give me a little push in the right direction, because I know the beginning and I have an idea of the end but I can't get through the middle...
Also, XOR and XNOR are the two functions that we just barely touched but that I have not been able to get my head around. I understand the whole "equality gate"/"inequality gate" idea but I do not understand how to recognize this in an expression or put the function to use. I haven't been able to find anything detailed online, either.
I was simply told if you see
\overline A \cdot B + A \cdot \overline B
then you "know" its an XOR function. How do I "prove" this? What about XNOR?
Sorry about the big post, I hope someone can point me in the right direction! Thanks for readin if you've gotten the whole way down here
I have got down to
