simplifying an equation
Discussion in 'Math' started by kokkie_d, Sep 12, 2013.
  1. kokkie_d
    Thread Starter Active Member
    Jan 12, 2009
    72
    suppose I have the following equation:
    \frac{a*b+a*R}{b+R}
    I threw this in maple and on wolfram alpha and Matlab just to see what they do with it to simplify and all came back with: a
    Would someone be able to explain how to go about achieving this?
    thanks in advance
  2. kokkie_d
    Jan 12, 2009
    72
    Just saw the solution;
    \frac{a*b+a*R}{b+R} = \frac{a(b+R)}{b+R}=a
    red faced person typing this. lol
  3. WBahn
    Mar 31, 2012
    18,087
    4,917
    Don't fret. We all occasionally sit staring at something for a long time only to see (or have pointed out to us) the most simple, obvious solution. It seems like you often spot the solution yourself only after asking someone else -- and I suspect that is not coincidence. The act of explaining the problem to someone else forces you to view the problem somewhat anew.
    kokkie_d likes this.
  4. kokkie_d
    Jan 12, 2009
    72
    So true.
    Where is the like button. lol
  5. WBahn
    Mar 31, 2012
    18,087
    4,917
    To the far right bottom of the post. ;)
  6. MrChips
    Oct 2, 2009
    12,638
    3,456
    There is one condition.
    The result is a if and only if (b + R) ≠ 0.
