Hi
I have a schematic circuit that I made with Altium designer the problem that it is very crowded by wires and I don't know what can I do to make more clear, can I use ports ?? for example I need to connect to parts of the circuit to each other can I use a port in one part as an output and put another port in the other part as an input with the same name of the first ?? they will be connected then and if there is other ideas please tell me, thank you.
