Simplify using Boolean Algebra and DeMorgan's Theorems
Discussion in 'Homework Help' started by WC_demon, Dec 16, 2007.
  1. WC_demon
    Dec 16, 2007
    I'd like to get some insight as to how to complete this: (X''+Y')+XYZ+X''Y''+Z'
    Here are my steps:
    (X+Y')+XYZ+XY+Z'
    (X+Y')+XYZ+Y+Z'
    (X+Y')+XYZ+Z'
    (XY')+XYZ+Z'
    (XY')+XYZ+Z'
    This is as far as i could get.
  2. hgmjr
    Jan 28, 2005
    9,030
    214
    Review the material in this section of the AAC e-book.
    Several members have commented on the clarity of the explanation it provides for boolean expression manipulation.
    hgmjr
  3. agentofdarkness
    Oct 9, 2007
    42
    What does X" mean?
  4. WC_demon
    Dec 16, 2007
    that it's like two NOT gates, so it equals X
  5. hgmjr
    Jan 28, 2005
    9,030
    214
    Each tick merk equates to an overbar which is used to indicate negation. A double tick as WC_demon has indicated is the same as a double negation and therefore it equates to the non-negated variable.
    hgmjr
  6. agentofdarkness
    Oct 9, 2007
    42
    Thats what I figured. Whats the reasoning behind double negating a variable? I know its sometimes used when doing a NOR/NOR or NAND/NAND circuit like [F']' where F is some function (like ABC) but what about just one variable.
  7. Management
    Sep 18, 2007
    306
    Maybe it is acting like some sort of buffer. The double negation that is.
