simplify this...
Discussion in 'Math' started by jut, Mar 27, 2009.
  1. jut
    Thread Starter Senior Member
    Aug 25, 2007
    224
    e^{(-1+2j)t}+e^{(-1-2j)t}
    my attempt:
    e^{-t}e^{j2t} + e^{-t}e^{-j2t}
    e^{-t}(e^{j2t} + e^{-j2t})
    euler's identity says...
    cos(2t)=e^{j2t}+e^{-j2t}/2
    so...
    e^{(-1+2j)t}+e^{(-1-2j)t} = e^{-t}(2cos(2t))
    it seems right, but it's wrong! I checked the proof by substituting numbers into the original equation and the final equation and they evaluate to different numbers. :(
    Any help would be nice.
  2. Ratch
    Mar 20, 2007
    1,068
    jut,
    Your solution is correct, but your substitution is wrong. I plotted both the given expression and your solution. They were identical.
    Ratch
  3. jut
    Aug 25, 2007
    224
    Thanks. OK the solution was correct. I must have goofed up the substitution last night.
    Strangely enough, MATLAB simplified the expression to: 2*exp(-1)*cos(2*t)
    which was very close.
  4. Ratch
    Mar 20, 2007
    1,068
    jut,
    I disagree with both MATLAB and your assessment. 2*exp(-1)*cos(2*t) = 2*0.37*cos(2t) is a constant amplitude sinusoidal wave. The correct solution is an exponentially damped sinusoidal wave.
    Ratch
