Simplify Boolean Algebra
Discussion in 'Homework Help' started by azall122, Feb 8, 2008.
  1. azall122
    Feb 8, 2008
  2. luck
    Jan 25, 2008
    You Will want to clarify what you are asking in the future. (Also proof read your posts before you make them; it took me a few minutes to figure out some of the = signs were suppose to be + signs)
    First I factor (a+b'+c') into a and b'c.
    From the first term we know if a is high then the expression will be high because we have a OR stuff.
    We also know that if b'c is high then b'c*b' will also be high and because it is OR'ed with stuff the expression will be high
    First I factor (a'+b') into a' and b.
    From the 4 terms I have we can factor an a' out to get a'(1+b'+b+0). Because of that 1 we know if a is low then the function will be high because we are OR'ing a' with stuff
    This is straight up demorgan's.'s_laws
