Simplify Boolean Algebra Expression
Discussion in 'Homework Help' started by big_gnome69, Nov 27, 2014.
  1. big_gnome69
    Nov 27, 2014
    6
    in the easiest way how can this expression be simplified? what is the simplified answer? penchod.
  2. WBahn
    Mar 31, 2012
    18,087
    4,917
    Which expression are you talking about?
  3. big_gnome69
    Nov 27, 2014
    6
    ¬A.¬B.¬C + A.B.¬C + A.¬B.C + A.B.C what is this in its simplest form
  4. WBahn
    Mar 31, 2012
    18,087
    4,917
    First, this is a homework problem and so answers aren't supposed to be just given out.
    Second, as pointed out earlier, it depends on what the metrics are for "simple".
    For instance, which is "simpler", (A(BC)')' or A' + BC ?
    What are your metrics?
  5. big_gnome69
    Nov 27, 2014
    6
    a + bc.
  6. WBahn
    Mar 31, 2012
    18,087
    4,917
    It's A' + BC, just to keep us on the same page.
    Why do you say that this is "simpler"? Again, what metric are you using to decide when one expression is "simpler" than another.
    Using basic CMOS logic gates, the expression (A(BC)')' requires a 2-input NAND gate and a 2-input NOR gate which requires eight transistors and incurs two gate delays from input to output. The expression (A'+BC) requires an inverter, an AND gate, and an OR gate which total to fourteen transistors and four gate delays. So it is nearly twice as large and only half as fast. Is it still "simpler"? Depends on what your metrics are.
  7. big_gnome69
    Nov 27, 2014
    6
    i need whatever has the least amount of gates
  8. WBahn
    Mar 31, 2012
    18,087
    4,917
    What gates are you limited to? To match Boolean algebra, that would be NOT, AND, and OR in any width (so a 12 input AND gate would be legal). Or are you limited to 2-input gates? Are you limited to NOT, NAND, and NOR? This is a common limitation in the real world along with a maximum on the number of inputs to any one gate, often in the four range. Can you use XOR?
    In engineering, the answer is usually, "It depends," until all of the constraints are adequately established.
  9. big_gnome69
    Nov 27, 2014
    6
    yes xor can be used and were not limited to any gates
  10. WBahn
    Mar 31, 2012
    18,087
    4,917
    Okay, so then you need to show YOUR work on YOUR homework problem. And, actually, you need to keep in mind that this is the OP's thread and that you are technically hijacking it, but at least you are talking about the OP's original problem. So show your work and you and the OP can collaborate and we can provide hints and suggestions. We will not just give out answers.
    The main hint that you need to incorporate an XOR gate is contained in Post #9.
  11. big_gnome69
    Nov 27, 2014
    6
    why you gotta be so rude?
  12. djsfantasi
    Apr 11, 2010
    2,905
    878
    Listen, he is not the one being rude. He is following the rules of this section, which you have read presumably.
    In order to receive help here, you are required to show your work. That is so we can understand your question better, can see where you are getting stuck and answer appropriately.
  13. WBahn
    Mar 31, 2012
    18,087
    4,917
    What's so rude about expecting you to attempt your own homework?
