Simplifing my Circuit
Discussion in 'General Electronics Chat' started by ahmedzica, Jan 9, 2012.
  1. ahmedzica
    Jan 9, 2012
    20
    Let Rb= 1k , Rc=100 and Vcc= 5v
    Can anybody simplfy this circuit and explain why is Vcc-V(Rb)-V(Be)=0
  2. hgmjr
    Jan 28, 2005
    9,030
    214
    The above equation states that if you begin with the voltage applied to the circuit, 5V in this case and then you subtract the voltage drop across the resistor Rb and then you subtract the voltage across the base-emitter junction, you should end up with 0 volts.
    hgmjr
  3. wmodavis
    Oct 23, 2010
    737
    150
    It is also called Kirchoff's Voltage Law. The sum of voltage drops around a loop is equal to zero.
    [SIZE=+1]Kirchhoff's Voltage Law - Introduction[/SIZE]
    Kirchhoff's Voltage Law - KVL - is one of two fundamental laws in electrical engineering, the other being Kirchhoff's Current Law (KCL).
    • KVL is a fundamental law, as fundamental as Conservation of Energy in mechanics, for example, because KVL is really conservation of electrical energy.
    • KVL and KCL are the starting point for analysis of any circuit.
    • KCL and KVL always hold and are usually the most useful piece of information you will have about a circuit after the circuit itself.
  4. ahmedzica
    Jan 9, 2012
    20
    I already know that. But I'm wondering if we used KVL why ignored V(Re) as in the left loop
    Thanks for your help
  5. kubeek
    Sep 20, 2005
    4,687
    805
    Because Vbe is assumed constant and non-dependent on Ic, which it practically is.
  6. ahmedzica
    Jan 9, 2012
    20
    can you tell my which loop are you loooking at
  7. ahmedzica
    Jan 9, 2012
    20
    I really appreciate your efforts. and I know how to use KVL. But I can't imagine how this circuit would be if we replaced this Vcc (1 Terminal ) with 2 Terminal and Removed that ground over there
  8. Adjuster
    Dec 26, 2010
    2,147
    300
    If Vcc were replaced by a connection to another network, you would have another more complex circuit. If there is a particular circuit you are thinking about, perhaps you might want to explain what you have in mind
    What are you actually trying to analyse - the simple transistor circuit considered as a load on Vcc?
  9. ahmedzica
    Jan 9, 2012
    20
    Yes I want to calculate Ic and Vce
  10. kubeek
    Sep 20, 2005
    4,687
    805
    The loop is the one you posted first, Vcc-V(Rb)-V(BE)=0.
    Another one would be Vcc-V(Rc)-V(CE)=0. If you know that Ic=β*Ib then you should be able to calculate the rest you need.
  11. Adjuster
    Dec 26, 2010
    2,147
    300
    At low input voltages the current may be estimated approximately by supply current I of (Vcc) = (β+1)(Vcc-Vbe)/Rb.
    Since here Rb is only 10 times Rc it is likely that, with a reasonably high gain transistor, above a certain voltage the transistor will saturate. This is because (β+1)(Vcc-Vbe)/Rb will exceed Vcc/Rc. At higher input voltages therefore, I(Vcc) ≈ (Vcc-Vbe)/Rb + Vcc/Rc
    ahmedzica likes this.
  12. ahmedzica
    Jan 9, 2012
    20
    Oh i got it. But why saying (β+1) is it only β? and after saturation will we cut of the exceeded wave?
  13. ahmedzica
    Jan 9, 2012
    20
    I got it, huge thanks
