Simplification of Boolean Expression
Discussion in 'Homework Help' started by mathsfailure, Nov 28, 2009.
  1. mathsfailure
    Nov 28, 2009
    Hi guys,
    I need help with my homework regarding simplification of boolean algebra.
    X = A.B + C . (A.C +B)
    I'm not sure how to do the compliment as in the bar above the letter.
  2. mathsfailure
    Nov 28, 2009
    is it correct to do it this way
    (A+B+C) * (A+C+B)
    AA+AC+AB+BA+BC+BB+CA+CC+CB
    I'm kinda lost.
  3. mik3
    Feb 4, 2008
    4,846
    63
    I cant see bar letters in the equation. If you want to write bar letters write them like this: A'.
  4. mathsfailure
    Nov 28, 2009
    X = ]A.B' + C]' . (A'.C' +B')
    yup here it is.
  5. mik3
    Feb 4, 2008
    4,846
    63
    I will give you a hint:
    [A.B'+C]'=(A'+B).C'
    Try to simply it more.
  6. Fraser_Integration
    Member
    Nov 28, 2009
    142
    5
    de morgans theorem:
    A' + B' = (AB)'
    and
    A'B' = (A+B)'
  7. mathsfailure
    Nov 28, 2009
    ive simplified the equation to somewhat where i got confused
    (A'+B+C')(A'+C'+B')
    A'A' + A'C' + A'B' + BA' +BC'+BB'+C'A'+C'C'+C'B'
    A'+A'C'+A'B'+BA'+BC'+C'A'+C'+C'B'
    Confused
  8. mik3
    Feb 4, 2008
    4,846
    63
    You can continue by taking common factors as to make some terms zero. However, I think it is easier to proceed like this:
    (AB'+C')'(A'C'+B')=(A'+B)C(A'C'+B')=(A'C+BC)(A'C'+B')=A'CA'C'+A'B'C+BCA'C'+BB'C
    Then apply the rule:
    AA'=0
    to simplify the final expression.
  9. Ratch
    Mar 20, 2007
    1,068
    mathsfailure,
    You will find the program in the link below to be useful. It gives the minterms of any Boolean expression. If the minterms of the problem match your solution or your intermediate simplifications, then you know you did not make a mistake with the algebra. Once you know the minterms, you can simplify the Boolean expression with a Karnaugh map. Also search for threads in this forum for "logic".
    Ratch
    http://forum.allaboutcircuits.com/showthread.php?p=135582#post135582
