Simplest voice activated car ignition
Discussion in 'The Projects Forum' started by SoftSparky, Oct 19, 2010.
  1. SoftSparky
    Oct 15, 2010
    10
    Hi.
    I have quickly searched the site for something similar, but I've found quite the right thing - either two high-tech (speaker ident, etc) or just voice switch.
    I envisage a system that can store just a single syllable word and 'unlock' the ignition on it's repeat.
    pic's seem to be fairly common for projects of this scale, so I wonder is this the way to go or is there a cheap (ideally all in one) IC that is already setup for such a thing - ideally under £10 & easily available?
    Cheers.
  2. Kermit2
    Feb 5, 2010
    3,854
    968
    activation is not the problem here. How much 'identification' are you wanting the circuit to perform?
    reacting to sound is simple. reacting to a SPECIFIC sound is not so simple. a dual tone decoding scheme would be simple to implement, a complex mixture of frequencies and timing(voice) would be VERY hard to implement.
  3. SoftSparky
    Oct 15, 2010
    10
    Thanks - as I said I only require one syllable for the ident. Not the speaker.
    I know there's ccts out there out to do this (& a lot more speech recognition wise) but they are relatively expensive.
    A switch to drive a relay on the o/p...
    Thanks.
  4. SoftSparky
    Oct 15, 2010
    10
    Can you explain 'dual tone'? Thx.
  5. Kermit2
    Feb 5, 2010
    3,854
    968
    It is the scheme used in all 'touch tone' phones. Pick up a phone and put it to your ear and press a button. The tone you hear is a mixture of two pure sinewave tones. Press the buttons aligned in a verticle row. You will hear a central 'note' and some variations in the background that is the second tone that is different for each button going vertically. Do the same with a horizontal row and you will hear a differrent 'note' that changes as you go across the buttons.
    Each row and each column has a 'tone' assigned to it. pressing the button put the note for that row AND that column on the same line.
    Dual Tone Modulated Freq. DTMF
    Google it to learn more
