Simplest 200-400KHz input circuit for a DC-DC converter.
Discussion in 'General Electronics Chat' started by systemlordanubis, Sep 1, 2015.
  1. systemlordanubis
    Jul 30, 2015
    17
    Hi All,
    Due to a slight miscommunication, I've purchased some Wurth DC-DC converters (#7491196212) which require a frequency of 200-400KHz on the input to function properly.
    I'm wanting to utilise a 24v DC source as the input voltage, but need to know the simplest method of getting this to the correct the frequency required to make these DC-DC converters function as desired.
    Anubis.
  2. blocco a spirale
    Jun 18, 2008
    1,462
    370
    Those are transformers not DC-DC converters. Another slight miscommunication, perhaps?
  3. systemlordanubis
    Jul 30, 2015
    17
    Yes, true, on their site they're listed as "Transformer for DC/DC Converter", but that doesn't really answer the question at hand as to how one would obtain the desired frequency.
    Anubis.
  4. blocco a spirale
    Jun 18, 2008
    1,462
    370
    What is the required specification?
  5. systemlordanubis
    Jul 30, 2015
    17
  6. blocco a spirale
    Jun 18, 2008
    1,462
    370
    What's the specification for the DC-DC converter?:rolleyes:
  7. systemlordanubis
    Jul 30, 2015
    17
    That's all I have I'm afraid - apart from that I'm trying to understand what's required to utilise these components in a circuit to take a 24VDC input and get a 12VDC output from these transformers.
    Thanks.
  8. blocco a spirale
    Jun 18, 2008
    1,462
    370
    And the output current should be?
  9. systemlordanubis
    Jul 30, 2015
    17
    The transformers are related to 1.6A on their 12v output, so somewhere close to this would be good as the current draw will be different for each place that these are being used, but the current draw should never exceed 1.3A
  10. blocco a spirale
    Jun 18, 2008
    1,462
    370
    Why don't you just by some DC-DC converters?
    It doesn't make sense to buy transformers and then try and find an application for them.
    absf likes this.
  11. systemlordanubis
    Jul 30, 2015
    17
    Exactly - this is what the miscommunication was all about. For the project I'm working on, I have a readily available large selection of 24VDC power supplies and my project requires 12V and 5V source, I had thought to utilise these two versions of component to give me the 12V and 5V sources from the single 24V source.
    Regardless, I've now got a bunch of these transformers and no way to utilise them; seeing as I'm in this predicament I thought it would be a good lesson anyway to see what's required to actually make these transformers do the job they're designed for and learn something in the process. Even if it ends up being more costly than simply buying a ready-made DC-DC converter (which I'll likely do in the future), at least this way I've not wasted these components and got something (better understanding) out of it.
    Hope that clarifies why I'm perusing this angle rather than just dumping them and buying something off the shelf.
  12. blocco a spirale
    Jun 18, 2008
    1,462
    370
    The thing is, you need someone to design a custom DC-DC converter using these transformers which is not a trivial task. Even building it would be tricky because you would be dealing with surface mount devices operating at Radio Frequency.
    It's not just a case of sticking pulsed 24V at 200kHz+ in at one end and taking 12VDC out the other. The output must be regulated, protected against over-current and over-temperature, filtered to prevent RF entering whatever is being powered and the whole thing has to be designed and built in such a way that it doesn't act like a radio transmitter. This is why everyone (including professional electronic engineers) buys them off-the-shelf from Traco or similar.
    Roderick Young likes this.
  13. systemlordanubis
    Jul 30, 2015
    17
    Right, understood, well shall put this down to lesson learnt and thank you very much for your replies.
    Anubis.
