Simple Transmission Line Question
Discussion in 'Homework Help' started by xz4chx, May 5, 2014.
  1. xz4chx
    Sep 17, 2012
    71
    A measurement of a transmission line at 1 [GHz] has voltage maximum at z= -31 [cm] with a magnitude of 1 [V]. The closest voltage minima (the minima that are the closest to the indicated voltage maximum) are at z = -34 [cm] and -28 [cm] with a magnitude of 0 [V]. Characteristic impedance is 50 [Ω] and place at z=0.
    a) What is the relative permittivity of the line?
    Formulas that could help
     \lambda= \frac {\lambda_0}{\sqrt {\epsilon_r}}
     \lambda_0 = c/f
     \lambda_0 = \frac {3*10^8} {1*10^9} = .3 meters
     \lambda = \delta V_{minima} = 6 centimeters * 10^{-2} = .06 meters
     (\frac {\lambda_0}{\lambda})^2 = \epsilon_r
     \epsilon_r = 25
    My solutions answer is:
     \epsilon_r = 6.25
    which means the ratio of  \frac {\lambda_0}{\lambda} needs to be half of what i got, and i don't understand what i did wrong.
  2. w2aew
    Member
    Jan 3, 2012
    219
    64
    Think about this. For a standing wave, is the distance between the maximum and the closest minimum measured in wavelengths. Or, what is the distance in wavelengths between two consecutive nodes (minimums)? Did you factor this into your calculations?
    anhnha likes this.
  3. KL7AJ
    Nov 4, 2008
    2,043
    292
    Here's how you can check your work, using the Velocity Factor. At 1GHz, the wavelength in free space is 30cm. The distance between two nulls, per your measurement is -34-(-28), which is 6 cm, which is 1/2 wavelength. A full wavelength (as measured) is 12 cm. Your velocity factor is 12cm/30cm, which is .4.
    The relative permittivity is the reciprocal of the square of the velocity factor. So 1/.4^2 is indeed 6.25.
    Your calculations are correct, I believe your actual measurements are in error. The VF should be on the order of 80-90% for air dielectric.
    Eric
    anhnha likes this.
  4. xz4chx
    Sep 17, 2012
    71
    If there is a voltage minima at -34 [cm] and -28 [cm], i don't understand how that is only .5 wavelengths? There is a maximum between them at -31 [cm]. So if the two minima (through) of the wave are at -34 [cm] and -28 [cm], isn't one wavelength from through to through or in this case minima to minima?
  5. xz4chx
    Sep 17, 2012
    71
    For all my smith chart calculations, my teacher uses a wavelength of 12 [cm].
  6. KL7AJ
    Nov 4, 2008
    2,043
    292
    No...minima to minima (or maximum to maximum is 1/2 wave.
    Watch this!
    http://www.youtube.com/watch?v=SbVbMR6jmSI
    Eric
  7. xz4chx
    Sep 17, 2012
    71
    If I have the function sin(x)
    Is the minima at 0 or - 1?
  8. anhnha
    Apr 19, 2012
    776
    48
    I think this may help.
    BTW, this is standing wave. You need to read about that.
    xz4chx likes this.
  9. xz4chx
    Sep 17, 2012
    71
    That makes perfect sense. Thank you. I understand it now
    anhnha likes this.
  10. anhnha
    Apr 19, 2012
    776
    48
