Hello kind people! I want to represent the light falling on a photodiode as the voltage across a resistor and then amplify that voltage such that the minimum is between 0-1V and the maximum is between 4-5V. This then gets fed into an ADC.
http://harryysherwood.files.wordpress.com/2013/09/schemeit-project.png
The individual blocks of the above circuit appear to work fine, but my problem has been connecting the first (transistor) to the second (741 op-amp). Does anybody have any advice for how these two should be connected so that I can achieve what I need to? I am also aware that there may be other mistakes in how I've wired up my op-amp, so do let me know if the middle bit needs re-designing!
Thank you so much!
Thank you so much!
