Simple Touch LED Circuit
Discussion in 'The Projects Forum' started by bgage, Feb 6, 2007.
  1. bgage
    Feb 6, 2007
    A long time ago I had a schematic that consisted of two transistors, 9v battery, LED, and other resistors.
    I have looked hi and low and can't find it around my house and have search on the internet with a no go.
    So I found this web page and was hoping that you all might help.
    This this circuit I would demonstrate it to kids by having kids hold hands in a circle and also touch each end of the touch switch. If any kid let go then the LED would go off. It worked very well.
    Any ideas?
    Thanks in advance
  2. kender
    Jan 17, 2007
    This reminds me of a prank, which one of my friends has pulled on me once. He had put on rubber boots, walked next to an unmarked electric fence and grabbed it with one hand. When grabbed it, he didn’t get shocked immediately, because the boots insulated him from the ground. Unknowingly, I walked up to him and he stretched his hand for a handshake. I stretched my hand too and got shocked the moment I touched him. I was wearing flip-flops and I had a good ground path. Of course my friend got shocked as much as I did, but the difference is that he was expecting it.
  3. spirit_viewer
    Jan 11, 2005
    Try this circuit; you may have to play around with R1 value but crrectly chosen it should work fine.
  4. bgage
    Feb 6, 2007
    Thanks... I'll give it a try!
  5. hgmjr
    Jan 28, 2005
    Here is another circuit that uses a darlington-pair connection of the same two transistors to increase the input impedance of the overall circuit.
