Simple timing circuits
Discussion in 'General Electronics Chat' started by briscoe, Jun 1, 2013.
  1. briscoe
    Jun 1, 2013
    Hey everyone, I've got an assignment at school which uses timing circuits and as a class we have done absolutely nothing on timing circuits and I have no idea how to make one, how they work or anything like that. Essentially, the assignment involves designing a mechanical timing device (a Rube Goldberg machine) and then creating an electrical timing circuit that will give off an output of some kind at the same time the Rube Goldberg machine finishes.
    To summarize, I'm looking for an easy to construct timing circuit which can be adjusted easily and the theory of how it works.
    I tried researching myself but didn't understand anything. I'm not too savvy with the circuitry lingo so please be easy on me.
    Thanks.
  2. Dodgydave
    Jun 22, 2012
    5,155
    772
    For the electrical timing use a 555 timer chip, as for the 'Rube Goldberg' look on You-tube.
    Bernard likes this.
  3. Shagas
    May 13, 2013
    802
    74
    Timing? as in you press a button and the circuit goes from state A to state B for an adjustable period of time and then back to A?
    If so , then you can make it using a multivibrator . Basically when you input a signal it latches to a state and when you input another signal then it goes back into it's original state. Or you can make it that you input a signal , or push a button and after a certain amount of time the circuit reverts back to it's original state (monostable multivibrator)
    I've got a few tutorials on those on youtube if you want to check them out .
    I think what you want is the monostable one (that is if I correctly understood what you are asking )
    the intro:
    http://www.youtube.com/watch?v=hWeITjnAjeY
    And the monostable one (press button and circuit switches on for an adjustable period of time) :
    http://www.youtube.com/watch?v=AxKzGV76_1M
  4. briscoe
    Jun 1, 2013
    I only have one question, how do you change the time the circuit takes? This is important because I don't know how long the Rube Goldberg Machine will take and I need to be able to change it easily. Dodgydave, could I replace resistor Rt with a variable resistor?
  5. absf
    Dec 29, 2010
    1,493
    374
    Sure, the bigger the Rt, the longer the time delayed. You can also increase Ct, if Rt becomes too large (>10M)
    Allen
  6. briscoe
    Jun 1, 2013
    Would just like to thank you all immensely for this; 2 months later and on testing day mine was the only group with with a 100% working timer circuit and, using the formula provided I managed to perfectly calibrate it to our Rube Goldberg Machine. No one else managed to find such an in depth resource and I cannot express my gratitude to you guys for this rather trivial thing :D
    absf likes this.
